1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: errlogPrintf in OSD implementation
To: "'EPICS Tech-Talk'" <[email protected]>
Date: Thu, 12 May 2005 10:14:01 +0900
Hi all,
We are implementing OSD-library of ITRON referring to the existing ones,
such as RTEMS, VxWorks and so forth.
In those libraries, errlogPrintf is used to print out error messages from
epicsThread, epicsEvent and epicsSignal.
On the other hand, APIs in those facilities are used to implement
errlogPrintf itself.
So, a trivial bug in the library under construction caused a loop of
recursive call like:
epicsSignal ->
errlogPrintf ->
epicsSignal ->
errlogPrintf ->
Though it might not happen once the OSD-library will have been
well-debugged, I guess it would be better not to use errlogPrintf in the
OSDs which are used to implement errlogPrintf itself.
Could anyone have advice or comments on this?
Thanks a lot in advance.
J. Odagiri
High Energy Accelerator Research Organization (KEK),
Oho 1-1, Tsukuba, Japan
RE: errlogPrintf in OSD implementation Jeff Hill
Prev: RE: excessive ioc memory utilization Jeff Hill
Next: RE: errlogPrintf in OSD implementation Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
