Jun-ichi Odagiri san wrote:
> errlogPrintf itself. So, a trivial bug in the library
> under construction caused a loop of recursive call like:
> epicsSignal ->
> errlogPrintf ->
> epicsSignal ->
> errlogPrintf ->
I assigned Mantis entry 200.
Thanks for your bug report.
PS: I hope that you have found a suitable C++ compiler for EPICS
and the ITRON architecture?
Jeff
> -----Original Message-----
> From: Jun-ichi Odagiri [mailto:[email protected]]
> Sent: Wednesday, May 11, 2005 7:14 PM
> To: 'EPICS Tech-Talk'
> Subject: errlogPrintf in OSD implementation
> Hi all,
> We are implementing OSD-library of ITRON referring to the
> existing ones,
> such as RTEMS, VxWorks and so forth.
> In those libraries, errlogPrintf is used to print out error
> messages from
> epicsThread, epicsEvent and epicsSignal.
> On the other hand, APIs in those facilities are used to
> implement
> So, a trivial bug in the library under construction caused a
> loop of
> epicsSignal ->
> errlogPrintf ->
> epicsSignal ->
> errlogPrintf ->
> Though it might not happen once the OSD-library will have been
> well-debugged, I guess it would be better not to use
> errlogPrintf in the
> OSDs which are used to implement errlogPrintf itself.
> Could anyone have advice or comments on this?
> Thanks a lot in advance.
> J. Odagiri
> High Energy Accelerator Research Organization (KEK),
> Oho 1-1, Tsukuba, Japan
- errlogPrintf in OSD implementation Jun-ichi Odagiri
Re: excessive ioc memory utilization Benjamin Franksen
<2005>
2025
2026
build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
<2005>
2025
2026
