Vladimir,
I typically use the native win32 port of EPICS instead
of the cygwin port. The cygwin port uses the cygwin POSIX emulation interfaces
layered on WIN32. There have been some problems with that configuration in the
past, but I have not played with it recently. There might also be an option to build
the native win32 port with cygwin tools, but no one has attempted to create the
appropriate EPICS configuration files so far. I have used both visual C++ and
the free Borland distribution to build the native win32 port.
Jeff
-----Original Message-----
[mailto:[email protected]]
Sent: Thursday, May
12, 2005 3:18 PM
To: [email protected]
Subject: build base 3.14.7 on
Windows XP under cygwin
I am trying to build base EPICS 3.14.7 on Windows XP using
latest version of cygwin and I just wondering if someone did it lately.
It looks like I am doing something wrong because what I saw
was:
1) missing file README@vxWorks,
I had to import it into the directory base-3.14.7/src/makeBaseApp/top/exampleBoot/ioc
from the internet
2) I had to remove line #25 (blank line) from
base-3.14.7/src/dbStatic/dbLex.l (otherwise compillation failed)
3) now I have problem with menuConvert.dbd in
base-3.14.7/src/bpt directory
$ pwd
/epics3.14.7/base-3.14.7/src/bpt
$ make cygwin-x86
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86
make[1]: Entering directory `/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
../../../bin/cygwin-x86/dbToMenuH.exe ../menuConvert.dbd
../O.Common/menuConvert
.h
Error "syntax error" Last token "menu"
input line: menu(menuConvert) {
in: file ../menuConvert.dbd line 10
db_parse returned -1
Terminal error For input file ../menuConvert.dbd
make[1]: *** [../O.Common/menuConvert.h] Error 255
make[1]: Leaving directory `/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
make: *** [cygwin-x86] Error 2
Can someone give any hint?
- build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
RE: excessive ioc memory utilization Jeff Hill
VxStats Rees, NP (Nick)
<2005>
2025
2026
RE: build base 3.14.7 on Windows XP under cygwin Mark Rivers
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
