I have built 3.14.7 with cygwin in the
last 2 months with no problems. What version of cygwin are you using? I can
compare with the version I am using, which I can find out tomorrow.
I am trying to build base EPICS 3.14.7 on Windows XP using
latest version of cygwin and I just wondering if someone did it lately.
It looks like I am doing something wrong because what I saw
was:
1) missing file README@vxWorks,
I had to import it into the directory
base-3.14.7/src/makeBaseApp/top/exampleBoot/ioc from the internet
2) I had to remove line #25 (blank line) from
base-3.14.7/src/dbStatic/dbLex.l (otherwise compillation failed)
3) now I have problem with menuConvert.dbd in
base-3.14.7/src/bpt directory
$ pwd
/epics3.14.7/base-3.14.7/src/bpt
$ make cygwin-x86
make -C O.cygwin-x86 -f .../Makefile TOP=../../.. T_A=cygwin-x86
make[1]: Entering directory `/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
.../../../bin/cygwin-x86/dbToMenuH.exe .../menuConvert.dbd
.../O.Common/menuConvert
..h
Error "syntax error" Last token "menu"
input line: menu(menuConvert) {
in: file .../menuConvert.dbd line 10
db_parse returned -1
Terminal error For input file ../menuConvert.dbd
make[1]: *** [../O.Common/menuConvert.h] Error 255
make[1]: Leaving directory `/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
make: *** [cygwin-x86] Error 2
Can someone give any hint?
- Re: build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
Re: VxStats Carl Lionberger
<2005>
2025
2026
RE: build base 3.14.7 on Windows XP under cygwin Jeff Hill
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
