1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: build base 3.14.7 on Windows XP under cygwin
To: Mark Rivers <[email protected]>, [email protected]
Date: Mon, 16 May 2005 09:31:03 -0500
I was using cygwin setup.exe version 2.457.2.2 to install cygwin on my XP
Vladimir
----- Original Message -----
Sent: Sunday, May 15, 2005 9:12 PM
Subject: RE: build base 3.14.7 on Windows XP under cygwin
I have built 3.14.7 with cygwin in the last 2 months with no problems.  What version of cygwin are you using?  I can compare with the version I am using, which I can find out tomorrow.
From: Vladimir Sirotenko [mailto:[email protected]]
Sent: Thursday, May 12, 2005 4:18 PM
To: [email protected]
Subject: build base 3.14.7 on Windows XP under cygwin
I am trying to build base EPICS 3.14.7 on Windows XP using latest version of cygwin and I just wondering if someone did it lately.
It looks like I am doing something wrong because what I saw was:
1) missing file README@vxWorks, I had to import it into the directory base-3.14.7/src/makeBaseApp/top/exampleBoot/ioc from the internet
2) I had to remove line #25 (blank line) from base-3.14.7/src/dbStatic/dbLex.l (otherwise compillation failed)
3) now I have problem with menuConvert.dbd in base-3.14.7/src/bpt directory
$ pwd
/epics3.14.7/base-3.14.7/src/bpt
$ make cygwin-x86
make -C O.cygwin-x86 -f .../Makefile TOP=../../.. T_A=cygwin-x86
make[1]: Entering directory `/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
.../../../bin/cygwin-x86/dbToMenuH.exe .../menuConvert.dbd .../O.Common/menuConvert
..h
Error "syntax error"  Last token "menu"
input line: menu(menuConvert) {
   in: file .../menuConvert.dbd line 10
db_parse returned -1
Terminal error For input file ../menuConvert.dbd
make[1]: *** [../O.Common/menuConvert.h] Error 255
make[1]: Leaving directory `/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
make: *** [cygwin-x86] Error 2
Can someone give any hint?
Vladimir
RE: build base 3.14.7 on Windows XP under cygwin Mark Rivers
Prev: RE: build base 3.14.7 on Windows XP under cygwin Mark Rivers
Next: RE: build base 3.14.7 on Windows XP under cygwin Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
