1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: build base 3.14.7 on Windows XP under cygwin
To: Janet Anderson <[email protected]>
Cc: [email protected]
Date: Mon, 16 May 2005 16:25:24 -0500
Thanks, that was it, you have to install cygwin with DOS as default text file type, now everything looks ok
Vladimir
----- Original Message ----- From: "Janet Anderson" <[email protected]>
To: "Vladimir Sirotenko" <[email protected]>
Sent: Monday, May 16, 2005 2:58 PM
Try selecting DOS as the "Default Text File Type" when executing
the cygwin setup.exe.
Jnaet
Vladimir Sirotenko wrote:
I was using cygwin setup.exe version 2.457.2.2 to install cygwin on my XP
 Vladimir
    To: Vladimir Sirotenko <mailto:[email protected]> ;
    [email protected] <mailto:[email protected]>
    Sent: Sunday, May 15, 2005 9:12 PM
    Subject: RE: build base 3.14.7 on Windows XP under cygwin
     I have built 3.14.7 with cygwin in the last 2 months with no
    problems.  What version of cygwin are you using?  I can compare with
    the version I am using, which I can find out tomorrow.
    From: Vladimir Sirotenko [mailto:[email protected]]
    Sent: Thursday, May 12, 2005 4:18 PM
    To: [email protected] <mailto:[email protected]>
    Subject: build base 3.14.7 on Windows XP under cygwin
     I am trying to build base EPICS 3.14.7 on Windows XP using latest
    version of cygwin and I just wondering if someone did it lately.
It looks like I am doing something wrong because what I saw was:
1) missing file README@vxWorks <mailto:README@vxWorks>, I had to
import it into the directory
base-3.14.7/src/makeBaseApp/top/exampleBoot/ioc from the internet 2) I had to remove line #25 (blank line) from
base-3.14.7/src/dbStatic/dbLex.l (otherwise compillation failed)
    3) now I have problem with menuConvert.dbd in base-3.14.7/src/bpt
    directory
     $ pwd
    /epics3.14.7/base-3.14.7/src/bpt
     $ make cygwin-x86
    make -C O.cygwin-x86 -f .../Makefile TOP=../../.. T_A=cygwin-x86
    make[1]: Entering directory
    `/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
    .../../../bin/cygwin-x86/dbToMenuH.exe .../menuConvert.dbd
    .../O.Common/menuConvert
    ..h
    Error "syntax error"  Last token "menu"
    input line: menu(menuConvert) {
       in: file .../menuConvert.dbd line 10
     db_parse returned -1
    Terminal error For input file ../menuConvert.dbd
    make[1]: *** [../O.Common/menuConvert.h] Error 255
    make[1]: Leaving directory
    make: *** [cygwin-x86] Error 2
Can someone give any hint?
Vladimir
RE: build base 3.14.7 on Windows XP under cygwin Mark Rivers
Re: build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
Prev: RE: build base 3.14.7 on Windows XP under cygwin Mark Rivers
Next: Serial RS485 question Geng, Xiaosong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
Next: RE: build base 3.14.7 on Windows XP under cygwin Mark Rivers
