> I was using cygwin setup.exe version 2.457.2.2 to install cygwin on my
XP
I just upgraded my version of Cygwin to be the latest version of
everything, using the same version of the setup.exe as you.
I then executed the following script to define things:
$ cat /usr/local/bin/setup_epics
export
PATH="/usr/bin/:/usr/local/bin:/usr/X11R6/bin/:/corvette/usr/local/epics
/base/bin/cygwin-x86:
/corvette/usr/local/epics/extensions_devel/bin/cygwin-x86"
export EPICS_HOST_ARCH=cygwin-x86
export HOST_ARCH=cygwin-x86
I then went to the EPICS 3.14.7 base directory and did
$ make clean uninstall
$ make
It worked fine, I did not get any errors.
I am not using cygwin to cross-compile for any other architectures, I am
only using it to build for cygwin-x86 itself. Are you using it to
cross-compile?
-----Original Message-----
From: Vladimir Sirotenko [mailto:[email protected]]
Sent: Thursday, May 12, 2005 4:18 PM
To: [email protected]
Subject: build base 3.14.7 on Windows XP under cygwin
I am trying to build base EPICS 3.14.7 on Windows XP using latest
version of cygwin and I just wondering if someone did it lately.
It looks like I am doing something wrong because what I saw was:
1) missing file README@vxWorks, I had to import it into the directory
base-3.14.7/src/makeBaseApp/top/exampleBoot/ioc from the internet
2) I had to remove line #25 (blank line) from
base-3.14.7/src/dbStatic/dbLex.l (otherwise compillation failed)
3) now I have problem with menuConvert.dbd in base-3.14.7/src/bpt
directory
$ pwd
/epics3.14.7/base-3.14.7/src/bpt
$ make cygwin-x86
make -C O.cygwin-x86 -f .../Makefile TOP=../../.. T_A=cygwin-x86
make[1]: Entering directory
`/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
.../../../bin/cygwin-x86/dbToMenuH.exe .../menuConvert.dbd
.../O.Common/menuConvert
..h
Error "syntax error" Last token "menu"
input line: menu(menuConvert) {
in: file .../menuConvert.dbd line 10
db_parse returned -1
Terminal error For input file ../menuConvert.dbd
make[1]: *** [../O.Common/menuConvert.h] Error 255
make[1]: Leaving directory
make: *** [cygwin-x86] Error 2
Can someone give any hint?
Vladimir
Re: build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
<2005>
2025
2026
VxStats Rees, NP (Nick)
<2005>
2025
2026
