1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Galil Motor Controllers
To: "'Andreas Isenegger'" <[email protected]>, [email protected]
Date: Mon, 30 May 2005 12:11:16 -0400
Yes, but...
I quite like the Galil motor controllers because they are extremely versatile and quite reliable.
The built-in versions of operations like homing were not acceptable for our purposes, so we have written a large and extremely application-specific program that runs in the Galil and impliments three basic operations
1) home
2) slew to position with backlash correction
3) move slowly to position without backlash correction
These operations are controlled for each axis (X, Y, Z or W) by setting a command variable (XCMD, YCMD, ZCMD or WCMD) and rading back a custom status word (XSTATUS, YSTATUS, ZSTATUS, WSTATUS).  The EPICS code interfaces to the program in the Galil through these command variables and status values, not directly to the native Galil commands.
We also had to deal with a few other oddities.  For example, the serial ports are on a networked terminal server.  The terminal server buffers packets and there is no way to set the buffering time to zero.  This adds a major communications delay that prevents us from managing each axis independently.  Also, there are mechanical linages that require all three axes on one of our Galils to home simultaneously.
Our solution works for us, but has been customized to fit our application very precisely.  I am not sure it would generalize to other applications without putting in at least as much work to modify it as we did to develop it.  If you are still interested after all this discouragement, I could package up the relevant files for you, but this is not something I would contemplate supporting for the community.
Cheers,
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road           | 5071 West Saanich Road
Victoria, B. C. V9E 2E7          | Victoria, C.-B. V9E 2E7
Government of Canada             | Gouvernement du Canada
-----Original Message-----
Sent: Monday, May 30, 2005 6:45 AM
To: [email protected]
Subject: Galil Motor Controllers
Hi all,
Did anyone implement support for any type of these controllers?
Andreas
Prev: Galil Motor Controllers Andreas Isenegger
Next: Re: Galil Motor Controllers Jim Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Galil Motor Controllers Jim Thomas
Next: RE: Galil Motor Controllers Mark Rivers
