1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem during "make"
To: Chithra Karunakaran <[email protected]>
Date: Wed, 15 Jun 2005 17:22:55 +0200
EPICS base contains C++ code and uses the C++ standard library.
To run binaries that contain C++ code, the machine running the binary must at least have the C++ runtime libraries installed. Which libraries are needed depends on the operating system. Even different flavours of Linux may have different names or places for libraries.
You should run your package manager (or whatever your Linux was installed from) and try to select and install the C++ runtime and standard libraries. If you want to compile code for EPICS on the Linux platform, you will need the complete gnu C++ compiler on your machine.
In your case the EPICS installation was probably created on a machine that had everything installed, but you're trying to run it on a machine that misses the runtime libraries (in your case libstdc++.so.5).
Hope this helps...
Good luck!
Ralph
Chithra Karunakaran wrote:
Hi:
I am relatively new to linux and Epics. I am trying to
run the example program from the ApplDevGuide. When I
try to run the make file, I get the following error
messages.
Should I install C++ compiler?
Thanks
/home/sm/Epics/base-3.14.6/bin/linux-x86/dbExpand:
error while loading shared libraries: libstdc++.so.5:
cannot open shared object file: No such file or
directory
__________________________________________________________
Free antispam, antivirus and 1GB to save all your messages
Only in Yahoo! Mail: http://in.mail.yahoo.com
-- Ralph Lange [email protected] Tel: +49 30 6392-2117 BESSY Controls Group www.bessy.de Fax: ... -4859
Re: problem during "make" Maren Purves
problem during "make" Chithra Karunakaran
Prev: RE: cygwin-x86 Mark Rivers
Next: Re: Porting db file generation from 3.13 to 3.14 Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: problem during "make" Chithra Karunakaran
Next: Re: problem during "make" Maren Purves
