Is the time zone definition correct on the workstation that you run the
ArchiveExport on? I.e. does the 'date' command print the correct time?
Make sure that the environment variable TZ is set to the correct acronym
for your time zone. (Or that /etc/localtime comtains the correct zone.)
Your examples look like TZ is used to determine the start time, but
EPICS_TS_MIN_WEST is used to convert the timestamps of the exported
data. I'm not sure if this is the expected or correct behaviour, though.
Hope this helps,
Ralph
huangsong wrote:
Hello,
I used ArchiveExport to retrieve archived data of Channel Archiver.
When I use "-start" option, the time specified was not corresponded with retrieved timestamp. For example:
If I specified -start "06/22/2005 03:00:00", it really retrieved data started from "06/22/2005 10:00:00".
If I change EPICS_TS_MIN_WEST, the only difference is that the timestamp of the retrieved data is different.
Why? I have defined EPICS_TS_MIN_WEST (-420) and EPICS_TS_NTP_INET (localhost) in $EPICS_BASE/config/CONFIG_SITE_ENV.
btw, EPICS is 3.13.8
Channel Archiver is 1.10.2
Best wishes and regards,
Huang song
IHEP
[email protected]
2005.06.23
- Re: question about Channel Archiver huangsong
- question about Channel Archiver huangsong
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
