1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dynamic libraries location
To: Christophe Moins <[email protected]>
Cc: [email protected]
Date: Wed, 06 Jul 2005 11:07:15 -0400
Well ... generally spoken ...
the binary should find a library that matches the header files it was compiled against. It's not exactly important where that library is located, but the search path mechanisms for finding dynamic libraries (which heavily depend on the operating system) must be set up correctly to avoid the binary finding a wrong version.
There's a place within the EPICS configuration directories where you can set up the default search path that is compiled into the binaries. (The App Developer's should mention that somewhere.) Most operating systems allow for adding and/or overriding these paths through environment variables. Again, the exact way to do that depends on your OS.
The behavior of a library doesn't change with its location. Your binary probably finds a different library of the same name whose location is mentioned earlier in the search path list.
Hope this helps,
Ralph
Christophe Moins wrote:
Would someone know if there is any requirement concerning the use of dynamic libraries in an epics application ?
Should they be located in the lib/target directory of the epics base directory or can we use also libraries located in the /usr/local/lib ?
I ask this as I have not had the same behaviour of a library according to the directory where it was stored.
Thanks Christophe
dynamic libraries location Christophe Moins
Prev: RE: VDCT Support Rees, NP (Nick)
Next: RE: VDCT Support Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: dynamic libraries location Christophe Moins
Next: Customer Services Representatives needed ASAP Worotel Communications Company
