David M. Kline wrote:
i use something like this:
/* EPICS base version-specific definitions (must be performed first) */
#include <epicsVersion.h>
#define LT_EPICSBASE(v,r,l) ((EPICS_VERSION<=(v)) &&
(EPICS_REVISION<=(r)) && (EPICS_MODIFICATION<(l)))
I believe your test is wrong - 3.13.8 would not pass
LT_EPICBASE(3,14,6), i.e., would not reach
the #error statement
It should be
( EPICS_VERSION<(v) ||
(EPICS_VERSION==(v) && ( EPICS_REVISION < (r) ||
( EPICS_REVISION == (r) &&
EPICS_MODIFICATION < (l) )
BTW: wrong implementations can be found in gtr and other packages which
illustrates
that having a correct version in a base header would make real sense.
Applications could
then test
#if !defined(LT_EPICSBASE) || LT_EPICSBASE(x,y,z)
#error
#endif
Regards
-- Till
/* Evaluate EPICS base */
#if LT_EPICSBASE(3,14,6)
#error "EPICS base must be 3.14.6 or greater"
#endif
you can make variations as well..
tschuess!
/david
Steven Hartman wrote:
I have a number of EPICS 3.13 VxWorks device/drivers which I would like to
start using with EPICS 3.14, also with VxWorks. From the "Converting an
EPICS R3.13 application to R3.14.4" document, I see that the addition of
two lines is the minimum that is required.
I would like to be able to maintain the same source code for both the 3.13
and 3.14 apps. So, what I would like to be able to do is something like:
#ifdef EPICS3_14
#include <epicsExport.h>
epicsExportAddress(dset,devFoo);
#endif
My question is, Is there already an `official' identifier defined to use
for such preprocessor conditionals that I can use for this?
Argonne National Laboratory
APS Operations Division (AOD)
Beamline Controls and Data Acquisition (BCDA)
EPICS Application Development and Beamline Support
David M. Kline
(630) 252-8639
[email protected]
- Re: #ifdef EPICS3_14 David M. Kline
- #ifdef EPICS3_14 Steven Hartman
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
