Till Straumann wrote:
David M. Kline wrote:
i use something like this:
/* EPICS base version-specific definitions (must be performed first) */
#include <epicsVersion.h>
#define LT_EPICSBASE(v,r,l) ((EPICS_VERSION<=(v)) &&
(EPICS_REVISION<=(r)) && (EPICS_MODIFICATION<(l)))
I believe your test is wrong - 3.13.8 would not pass
LT_EPICBASE(3,14,6), i.e., would not reach
the #error statement
It should be
( EPICS_VERSION<(v) ||
(EPICS_VERSION==(v) && ( EPICS_REVISION < (r) ||
( EPICS_REVISION == (r)
&& EPICS_MODIFICATION < (l) )
BTW: wrong implementations can be found in gtr and other packages
which illustrates
that having a correct version in a base header would make real sense.
Applications could
then test
i agree.
oops ... you are absolutely correct, i'm embarrassed. sorry to everyone
for the
misinformation... (i'll go crawl into a hole now.)
thanks for bringing this to my attention,
/david
#if !defined(LT_EPICSBASE) || LT_EPICSBASE(x,y,z)
#error
#endif
Regards
-- Till
/* Evaluate EPICS base */
#if LT_EPICSBASE(3,14,6)
#error "EPICS base must be 3.14.6 or greater"
#endif
you can make variations as well..
tschuess!
/david
Steven Hartman wrote:
I have a number of EPICS 3.13 VxWorks device/drivers which I would
like to
start using with EPICS 3.14, also with VxWorks. From the "Converting an
EPICS R3.13 application to R3.14.4" document, I see that the
addition of
two lines is the minimum that is required.
I would like to be able to maintain the same source code for both
the 3.13
and 3.14 apps. So, what I would like to be able to do is something
like:
#ifdef EPICS3_14
#include <epicsExport.h>
epicsExportAddress(dset,devFoo);
#endif
My question is, Is there already an `official' identifier defined to
use
for such preprocessor conditionals that I can use for this?
Argonne National Laboratory
APS Operations Division (AOD)
Beamline Controls and Data Acquisition (BCDA)
EPICS Application Development and Beamline Support
David M. Kline
(630) 252-8639
[email protected]
David M. Kline
(630) 252-8639
[email protected]
- Re: #ifdef EPICS3_14 Dirk Zimoch
- #ifdef EPICS3_14 Steven Hartman
- Re: #ifdef EPICS3_14 David M. Kline
- Re: #ifdef EPICS3_14 Till Straumann
<2005>
2025
2026
<2005>
2025
2026
