1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: iocLogServer change?
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 22 Jul 2005 08:22:07 +0200
Hi all,
coming back to an earlier proposal.
We have looked into the following message-chain( using Java Message Services):
IOC -> JMS-client(on IOC) -> JMS-Server -> JMS-Filters -> JMS-Receiver -> cmlogClient(Java) -> cmlogServer
Comment: JMS-Filters will allow to filter/ forward messages to several downstream JMS-Receivers. Potential receivers are: cmlog/ SMS (ShortMessageService)/ log file/ mail/ other filters/ other actions.
The only part missing is the implementation in 'C' or 'C++' of the JMS client (i.e. on vxWorks). The rest of the chain is straight forward and mostly already tested.
We will continue to work on this. Since the vxWorks part is not the highest priority for us at the moment it will take some time.
Any help would be appreciated.
-Matthias
Ron MacKenzie wrote:
Hi Carl,
The issue is that CMLOG comes packaged with an older version of ACE
(ACE 4.0).  That version did not support RTEMS.
So, I took some of the obvious approaches to that problem and they proved
difficult.  It looks like the API has changed across the last couple of
major releases of ACE.
Ron
|  Ron MacKenzie
|  http://www.slac.stanford.edu/~ronm/
|  mailto:[email protected]
|  This message is from me personally, and does not necessarily
|  reflect the opinion of Stanford University, SLAC, or the US DOE
On Thu, 21 Jul 2005, Carl Cork wrote:
Have you actually tried to build ACE on RTEMS? The ACE site
claims to support RTEMS and has comprehensive build/install
information:
http://www.cs.wustl.edu/~schmidt/ACE_wrappers/ACE-INSTALL.html
The RTEMS archives also have reported success building ACE
on i386 platforms:
    http://www.rtems.com/ml/rtems-users/2001/april/msg00030.html
    http://www.rtems.com/ml/rtems-users/2003/june/msg00118.html
The CMLOG Client and ClientD code don't appear to have too many VxWorks
dependencies.
Maybe porting to RTEMS would be easier than changing iocLogServer?
Allison, Stephanie wrote:
Hi All,
We're looking at upgrading iocLogServer so that it either writes
messages to a file, like it does now, or forwards the messages to the
cmlogServer (which would make iocLogServer be a cmlog client).  We
think it's easier to do this than to port the CMLOG client and daemon,
and particularly ACE, to our RTEMS IOCs.  Part of this effort would
also be to add support for messages that contain both ASCII text and
other ASCII "tags" like facility, status, severity, and task name.
Any comments? Dumb idea? Anybody interested in something like this? Should it be done in such a way that it can go into some future EPICS base version with the new features enabled via some configure file? Or left unbundled?
Stephanie Allison
SLAC/SSRL, SLAC/LCLS
Carl Cork                                 E-Mail:  [email protected]
Lawrence Berkeley National Lab               TEL: +1 510 486 4295
One Cyclotron Road, MS 6R2100                FAX: +1 510 486 5664
Berkeley, CA, USA 94720-8226                 WEB:  www.lbl.gov
Matthias Clausen                         Cryogenic Controls Group(MKS-2)
phone:  +49-40-8998-3256                Deutsches Elektronen Synchrotron
fax:    +49-40-8994-3256                                    Notkestr. 85
e-mail: [email protected]                           22607 Hamburg
WWW-MKS2.desy.de                                                 Germany
iocLogServer change? Allison, Stephanie
Re: iocLogServer change? Carl Cork
Re: iocLogServer change? Ron MacKenzie
Prev: Re: iocLogServer change? Ron MacKenzie
Next: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: iocLogServer change? Liyu, Andrei
