1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link
To: <[email protected]>
Cc: "Langebner, Anton" <[email protected]>
Date: Fri, 22 Jul 2005 09:57:03 +0200
Hello All,
I am referring to my e-mail from 11 July 2005. The problem coudn't be solved yet.
In the meantime, I got the latest version of dec21x40End.h/c from Wind River. It improved the situation, but didn't solve it to satisfaction. See below.
We are experiencing problems here with VxWorks 5.5 and EPICS 3.13.10. In
short, if a running IOC loaded with reasonable CA traffic is disconnected
from the network for 5 seconds and then reconnected, the network connection
will die forever (until reboot). No UDP, TCP, ICMP packets are processed by
the IOC anymore.
In more detail:
Whenever this happens, the serial debug console outputs messages like:
sendto failed: S_errno_ENOBUFS
0x195c160 (CA_online): ../online_notify.c: CA beacon error was
"S_errno_ENOBUFS"
Another observation is that I see several TCP and UDP sockets with 0.0.0.0
addresses, even before I let the system die. See below:
TEST-VME-ANDY > inetstatShow
Active Internet connections (including servers)
PCB Proto Recv-Q Send-Q Local Address Foreign Address (state)
1d392c0 TCP 0 0 129.129.129.245.5064 129.129.128.46.59589 ESTABLISHED
1d393c8 TCP 0 0 0.0.0.0.5064 0.0.0.0.0 LISTEN
1d39134 TCP 0 0 129.129.129.245.1034 129.129.128.46.6500 CLOSE_WAIT
1d38fa8 TCP 0 0 0.0.0.0.111 0.0.0.0.0 LISTEN
1d38d98 TCP 0 0 0.0.0.0.513 0.0.0.0.0 LISTEN
1d38b88 TCP 0 0 0.0.0.0.23 0.0.0.0.0 LISTEN
1d394d0 UDP 0 0 0.0.0.0.1028 0.0.0.0.0
1d3944c UDP 0 0 0.0.0.0.5064 0.0.0.0.0
1d3923c UDP 0 0 0.0.0.0.1027 0.0.0.0.0
1d38f24 UDP 0 0 0.0.0.0.1026 0.0.0.0.0
1d391b8 UDP 0 0 0.0.0.0.5065 0.0.0.0.0
1d38ea0 UDP 0 0 0.0.0.0.111 0.0.0.0.0
value = 1 = 0x1
TEST-VME-ANDY >
Has this maybe to do with the NFS client bug in VxWorks?
Finally: it doesn't seem to be an mbuf or cluster allocation problem. We are
using higher values than VxWorks default. When I check with mbufShow,
ifShow, inetstatShow, netStackDataPoolShow and netStackSysPoolShow, no
unusual numbers are shown, except:
I can see with netStackDataPoolShow, that the 128byte clusters decrease
dramatically from initially 400 free clusters to 250 or with more network
load even down to 0 after a disconnect/reconnect. However, they don't have
to become 0 in order to kill the network stack.
All help is appreciated.
Andreas
Andreas Isenegger
SLS Controls
Paul Scherrer Institute, WSLA/207
CH-5232 Villigen PSI, Switzerland
Tel/Fax: ++41 (56) 310 5125/4413
Prev: Re: iocLogServer change? Matthias Clausen
Next: announcing EPICS meeting on 6/ 7 Oct. before ICALEPCS Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Next: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
