1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link
To: "EPICS tech-talk" <[email protected]>
Date: Wed, 28 Sep 2005 17:12:44 +0200
Hello All,
Since I posted 2 e-mails in July 2005 seeking for help, I thought it would be worth informing you that the problem could be solved.
There are indeed some bugs in Wind River's N/W driver (dec21x40End.h/c) that cause the misbehavior of the IOC. I got new revisions of these files from Martin Niedermair, WRS Austria, which solve the issue. Strangely enough, a different support engineer of WRS sent me another revision of the same files, which doesn't fix the bug. About 2 years back, they were branched... . The latest official patch from WRS contains again different revisions of the files.
Thus, if you are experiencing troubles with IOC's disconnecting for 'no reasons', or reset ports of N/W switches to regain links to IOC's, build a new VxWorks image with the latest revision of these files.
Kind regards,
Andreas Isenegger
Andreas Isenegger
SLS Controls
Paul Scherrer Institute, WSLA/207
CH-5232 Villigen PSI, Switzerland
Tel/Fax: ++41 (56) 310 5125/4413
Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Ernest L. Williams Jr.
Prev: Re: striptool strangeness Dirk Zimoch
Next: VxWorks TIMEZONE hack, anyone? Steve Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Next: Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Ernest L. Williams Jr.
