1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in sequencer, V2.0.10 and earlier
To: "EPICS Tech-Talk" <[email protected]>
Date: Mon, 25 Jul 2005 15:30:33 -0700
Hello -
There is a bug in the sequencer, version 2.0.10 and earlier, seq/src/seq/seq_ca.c.  A pointer is being copied when a memory copy should be done instead.   For an RTEMS IOC, it causes a crash.  This bug is seen only if you happen to BOTH monitor and get a PV on another IOC and that other IOC is rebooted.  The second reboot of the other IOC after the sequence started causes the crash of the IOC running the sequence.  This is a very unusual situation.  The only reason we saw it is that we were upgrading device support to add db_post_event on a field and temporarily doing both gets and monitors until all IOCs could be rebooted.
Thanks to Till Straumann who used his RTEMS debugger to get a helpful stack trace.
Can someone add this fix to the next sequencer release?
The fix:
cvs diff -r SEQ-2-0-10
cvs diff: Diffing .
Index: seq_ca.c
RCS file: /afs/slac/g/lcls/cvs/epics/site/src/seq/src/seq/seq_ca.c,v
retrieving revision 1.1.1.1
retrieving revision 1.2
diff -r1.1.1.1 -r1.2
230c230,233
<           pDB->message = pvVarGetMess(pDB->pvid);
>             if (pvVarGetMess(pDB->pvid))
>                 pDB->message = Strdcpy(pDB->message, pvVarGetMess(pDB->pvid));
>             else
>                 pDB->message = Strdcpy(pDB->message, "unknown");
Thank you,
Stephanie Allison
SLAC/SSRL, SLAC/LCLS
Re: Bug in sequencer, V2.0.10 and earlier Andrew Johnson
Prev: announcing EPICS meeting on 6/ 7 Oct. before ICALEPCS Matthias Clausen
Next: Re: Bug in sequencer, V2.0.10 and earlier Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
