1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fwd: FW: Font problem when using EDM
To: [email protected]
Date: Mon, 29 Aug 2005 14:37:56 -0700 (PDT)
Anyone have some advice for Chithra?  It's been a while since I've thought
about StripTool or EDM.
Chris Larrieu
--- Chithra Karunakaran <[email protected]> wrote:
> Subject: FW: Font problem when using EDM
> Date: Mon, 29 Aug 2005 13:58:27 -0600
> From: "Chithra Karunakaran" <[email protected]>
> To: <[email protected]>
> Dear Christopher:
> I am developing EDM applications in a Linux machine.  I am trying to
> open StripTool through shell command tool in EDM. But I get the
> following error:
> Representation size 80 must match superclass's to override font
> John Sinclair asked me to do the export LANG=C;edm but still I get the
> above error. Do you have any suggestions?
> Thanks,
> Chithra.
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: August 26, 2005 1:05 PM
> To: Chithra Karunakaran
> Subject: Re: Font problem when using EDM
> Chithra,
> Redhat 7.2 was the first to use UTF-8 rather than ascii. Try doing
> export LANG=C;edm
> The version of edm is found by doing
>   edm -v
> When you run StripTool from the command line, do you get the same
> message?
> Also, see if your environment is significantly different when an edm
> invoked
> shell script is run; i.e. have the shell command do env. Then do the
> same
> command (env) from a terminal window.
> John
> On Friday 26 August 2005 1:51 pm, you wrote:
> > The simple shell commands work, like 'ls' and running '.exe' files.
> The
> > font problem comes only when I start the StripTool.
> > I tried in two machines with the following operating systems:
> > 1. Scientific Linux SL Release 4.0 (Beryllium) with openMotif
> > 2. Red Hat Linux release 7.2 (Enigma)with  openMotif
> > The EDM version and StripTool versions are:
> > 1. EDM:???
> > 2. StripTool: CA v2.4.3, Linked with CA:4.9
> > I am not able to find the version of EDM.
> > Thanks for your help.
> > Chithra.
Re: Fwd: FW: Font problem when using EDM Noboru Yamamoto
Prev: record reference manual Mark M. Ito
Next: [no subject] Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Fwd: FW: Font problem when using EDM Noboru Yamamoto
