[email protected] wrote:
Anyone have some advice for Chithra? It's been a while since I've thought
about StripTool or EDM.
This is not an dvice but just a report.
I run StripTool from edm but did not get the message Chithra mentioned.
I got the message "missing charsets in String to FontSet conversion"
when I started edm but NO message when started StripTool from edm.
My environment is:
EPICS 3.14.7
+ edm 1-10-1ze
+ StripTool 2.5.9.0
on Scientific Linux 2.4.21-27.0.2.EL
(running on VirtualPC on MacMini with MacOSX 10.4.2)
EPICS, edm and StripTool are build from the source code on this machine,
i.e. Scientific Linux.
Noboru
EPICS group/KEKB control group
KEK, JAPAN
Chris Larrieu
--- Chithra Karunakaran <[email protected]> wrote:
Subject: FW: Font problem when using EDM
Date: Mon, 29 Aug 2005 13:58:27 -0600
To: <[email protected]>
Dear Christopher:
I am developing EDM applications in a Linux machine. I am trying to
open StripTool through shell command tool in EDM. But I get the
following error:
Representation size 80 must match superclass's to override font
John Sinclair asked me to do the export LANG=C;edm but still I get the
above error. Do you have any suggestions?
Chithra.
-----Original Message-----
Sent: August 26, 2005 1:05 PM
To: Chithra Karunakaran
Subject: Re: Font problem when using EDM
Chithra,
Redhat 7.2 was the first to use UTF-8 rather than ascii. Try doing
export LANG=C;edm
The version of edm is found by doing
edm -v
When you run StripTool from the command line, do you get the same
message?
Also, see if your environment is significantly different when an edm
invoked
shell script is run; i.e. have the shell command do env. Then do the
same
command (env) from a terminal window.
John
On Friday 26 August 2005 1:51 pm, you wrote:
The simple shell commands work, like 'ls' and running '.exe' files.
The
font problem comes only when I start the StripTool.
I tried in two machines with the following operating systems:
1. Scientific Linux SL Release 4.0 (Beryllium) with openMotif
2. Red Hat Linux release 7.2 (Enigma)with openMotif
The EDM version and StripTool versions are:
1. EDM:???
2. StripTool: CA v2.4.3, Linked with CA:4.9
I am not able to find the version of EDM.
Thanks for your help.
Chithra.
- Fwd: FW: Font problem when using EDM caparomula-jlab
job openings for Gemini Observatory Matthieu Bec
3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
<2005>
2025
2026
[no subject] Dalesio, Leo `Bob`
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
