1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.14 build system doesn't cope with hyphens in IOC names
To: "Denison, PN (Peter)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 01 Sep 2005 09:02:06 -0400
We use hyphens in our IOC names under EPICS R3.14.7.
I don't remember making any modifications to support this.
For example,
[williams@lion test]$ makeBaseApp.pl -t example example
[williams@lion test]$ makeBaseApp.pl -i -t example my-new-ioc
The following target architectures are available in base:
    vxWorks-mv2100_v6
    vxWorks-mv5100_v6
    vxWorks-ppc603_T2-2
    vxWorks-ppc603_long
    vxWorks-ppc603
    linux-x86
    vxWorks-ppc604_T2-2
What architecture do you want to use? vxWorks-ppc603
[williams@lion test]$ ls
configure/  exampleApp/  iocBoot/  Makefile
[williams@lion test]$ ls  iocBoot/
iocmy-new-ioc/  Makefile  nfsCommands
Works perfect.
On Thu, 2005-09-01 at 13:48 +0100, Denison, PN (Peter) wrote:
> The build system in R3.14 won't cope with IOC names containing hyphens
> (or any other character permitted in filenames, but not permitted in C
> identifiers). This is a problem for us with our current naming
> convention. It occurs because the auto-generated
> <name>_registerRecordDeviceDriver.cpp file uses the app name to
> construct a function <name>_registerRecordDeviceDriver() that is then
> called from the st.cmd file.
> The following patch to base just converts all the non-allowed characters
> in the app name to underscores. Unfortunately, it relies on a change to
> the ioc templates for makeBaseApp.pl, introducing a "_CSAFEAPPNAME_"
> substitution where previously there was just "_APPNAME_".
> Is this a candidate for sneaking into R3.14.8? Can anyone suggest a
> better way?
> Index: src/registry/registerRecordDeviceDriver.pl
> --- src/registry/registerRecordDeviceDriver.pl	(revision 67)
> +++ src/registry/registerRecordDeviceDriver.pl	(working copy)
> @@ -15,6 +15,11 @@
>  $numberDeviceSupport = 0;
>  $numberDriverSupport = 0;
> +# PND 2005-08-31 avoid C errors by using only allowed characters in
> identifiers
> +# Requires a corresponding change in the substitution of st.cmd files
> +$c_bad_ident_chars = '[^0-9A-Za-z_]';
> +$subname =~ s/$c_bad_ident_chars/_/g;
>  open(INP,"$file") or die "$! opening file";
>  while(<INP>) {
>      next if m/ ^ \s* \# /x;
> Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
> --- src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common	(revision 67)
> +++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@Common	(working copy)
> @@ -9,7 +9,7 @@
>  ## Register all support components
>  dbLoadDatabase("dbd/_APPNAME_.dbd",0,0)
> -_APPNAME__registerRecordDeviceDriver(pdbbase)
> +_CSAFEAPPNAME__registerRecordDeviceDriver(pdbbase)
>  ## Load record instances
>  #dbLoadRecords("db/xxx.db","user=_USER_Host")
> Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
> --- src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS	(revision 67)
> +++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS	(working copy)
> @@ -7,7 +7,7 @@
>  dbLoadRecords("../../db/_APPNAME_.db","user=_USER_")
> Index: src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
> --- src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks	(revision 67)
> +++ src/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks	(working copy)
> @@ -16,7 +16,7 @@
>  cd top
>  #dbLoadRecords("db/_APPNAME_.db","macro=value")
> Index: src/makeBaseApp/makeBaseApp.pl
> --- src/makeBaseApp/makeBaseApp.pl	(revision 67)
> +++ src/makeBaseApp/makeBaseApp.pl	(working copy)
> @@ -14,6 +14,8 @@
>  %release = (TOP => $app_top);
>  @apps   = (TOP);
>  &GetUser;		# Ensure we know who's in charge
>  &readRelease("configure/RELEASE", \%release, \@apps) if (-r
> "configure/RELEASE");
>  &readRelease("configure/RELEASE.$ENV{EPICS_HOST_ARCH}", \%release,
> \@apps)
> @@ -93,6 +95,7 @@
>      $line =~ s/_TEMPLATE_TOP_/$app_template_top/go;
>      $line =~ s/_TOP_/$app_top/go;
>      $line =~ s/_APPNAME_/$appname/g;
> +    $line =~ s/_CSAFEAPPNAME_/$csafeappname/g;
>      $line =~ s/_APPTYPE_/$apptype/go;
>      $line =~ s/_ARCH_/$arch/go if ($opt_i);
>      $line =~ s/_IOC_/$ioc/g if ($ioc);
> @@ -122,6 +125,7 @@
>      foreach $ioc ( @ARGV ) {
>  	($appname = $ioc) =~ s/App$//;
> +	($csafeappname = $appname) =~ s/$c_bad_ident_chars/_/g;
>  	$ioc = "ioc" . $ioc unless ($ioc =~ /^ioc/);
>          if (-d "iocBoot/$ioc") {
>  	    print "iocBoot/$ioc exists, not modified.\n";
> @@ -137,6 +141,7 @@
>  foreach $app ( @ARGV ) {
>      ($appname = $app) =~ s/App$//;
>      $appdir  = $appname . "App";
>      if (-d "$appdir") {
>  	print "$appname exists, not modified.\n";
> Peter Denison, Senior Software Engineer
> Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11
> 0DE
> Tel: +44 1235 778511
3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
Prev: 3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
Next: RE: 3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
