1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 3.14 build system doesn't cope with hyphens in IOC names
To: "Denison, PN (Peter)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 01 Sep 2005 09:37:13 -0400
On Thu, 2005-09-01 at 14:29 +0100, Denison, PN (Peter) wrote:
> > -----Original Message-----
> > From: Ernest L. Williams Jr. [mailto:[email protected]]
> > Subject: Re: 3.14 build system doesn't cope with hyphens in IOC names
> > We use hyphens in our IOC names under EPICS R3.14.7.
> > I don't remember making any modifications to support this.
> > For example,
> > [williams@lion test]$ makeBaseApp.pl -t example example
> > [williams@lion test]$ makeBaseApp.pl -i -t example my-new-ioc
> > The following target architectures are available in base:
> >     vxWorks-mv2100_v6
> >     vxWorks-mv5100_v6
> >     vxWorks-ppc603_T2-2
> >     vxWorks-ppc603_long
> >     vxWorks-ppc603
> >     linux-x86
> >     vxWorks-ppc604_T2-2
> > What architecture do you want to use? vxWorks-ppc603
> > [williams@lion test]$ ls configure/  exampleApp/  iocBoot/  Makefile
> > [williams@lion test]$ ls  iocBoot/ iocmy-new-ioc/  Makefile
> nfsCommands
> > Works perfect.
> Sorry - I wasn't clear enough in my original explanation of the problem.
> It is in the substitution of "APPNAME" that problems occur with hyphens.
> In your example, the appname was "example", which doesn't contain
> hyphens (so no problem)
Still works for me:
[williams@lion test]$ makeBaseApp.pl -t example my-example
configure/  Makefile  my-exampleApp/
[williams@lion test]$ makeBaseApp.pl -i -t example my-example
    vxWorks-mv2100_v6
    vxWorks-mv5100_v6
    vxWorks-ppc603_T2-2
    vxWorks-ppc603_long
    vxWorks-ppc603
    linux-x86
    vxWorks-ppc604_T2-2
[williams@lion test]$ ls -l
total 16
drwxrwxr-x  2 williams williams 4096 Sep  1 09:32 configure/
drwxrwxr-x  3 williams williams 4096 Sep  1 09:33 iocBoot/
-rw-rw-r--  1 williams williams  391 Sep  1 09:32 Makefile
drwxrwxr-x  4 williams williams 4096 Sep  1 09:32 my-exampleApp/
iocmy-example/  Makefile  nfsCommands
> and you'd need to modify the st.cmd file by hand
> to change to example_registerRecordDeviceDriver from
> my-new-ioc_registerRecordDeviceDriver, also avoiding the problem.
Now modifying the st.cmd file has always been an issue with us.
However, given that one could have many Apps associated with one IOC it
was a good choice to choose the IOC name as the prefix.
Maybe, the script could ask what should be your main App?
> If you use the same name for the app and the ioc, both with a hyphen in,
> you'll see the problem.
> Peter Denison, Senior Software Engineer
> Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11
> 0DE
> Tel: +44 1235 778511
RE: 3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
Prev: RE: 3.14 build system doesn't cope with hyphens in IOC names Denison, PN (Peter)
Next: SNCSEQ... Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
