1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SNCSEQ...
To: "Laznovsky, Michael" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 01 Sep 2005 18:19:59 -0400
On Thu, 2005-09-01 at 15:07 -0700, Laznovsky, Michael wrote:
> Hi all- we're trying to build a modified version of the SNC (state program compiler)
> for local 3.14.6 development, and my attempts at making it use the test copy are falling short.
> I've tried telling configure/RELEASE where the test compiler is via:
> 	#If using the sequencer, point SNCSEQ at its top directory:
> 	SNCSEQ=/u/cd/xyz/work/seq-2.0.10
> ... but the build fails with:
> 	gmake[1]: Entering directory `/u/cd/xyz/tmp-xyz/ioc/configure'
> 	perl <SLACstuff>/epics/R3.14.6/base/configure/tools/convertRelease.pl -h solaris-sparc checkRelease
> 	Definition of SNCSEQ conflicts with SNCSEQ support.
> 	In this application configure/RELEASE defines
> 	        SNCSEQ = /u/cd/xyz/work/seq-2.0.10
> 	but SNCSEQ at  has
> 	        SNCSEQ = <SLACstuff>/epics/R3.14.6/site
Check your RELEASE file in "/u/cd/xyz/work/seq-2.0.10/<...>/configure"
Looks like you have SNCSEQ defined there.
> 	gmake[1]: *** [checkRelease] Error 1
> I don't see where the second definition in the error comes from.  It's not
> anywhere in the installed EPICS area that I can find.
> thanks,
> Mike
SNCSEQ... Laznovsky, Michael
Prev: SNCSEQ... Laznovsky, Michael
Next: archive viewer installation problem Christophe Moins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: SNCSEQ... Andrew Johnson
