gmake[1]: Entering directory `/u/cd/xyz/tmp-xyz/ioc/configure' perl <SLACstuff>/epics/R3.14.6/base/configure/tools/convertRelease.pl -h solaris-sparc checkRelease Is the text above *exactly* as reported by the tool, or did you edit the two "<SLACstuff>" parts? I note that the second line above has <SLACstuff> in the path to the convertRelease.pl script, and that looks to be part of the problem. Check whether SNCSEQ (or SLACstuff even) is found anywhere in your <base>/configure directory. Do you use an automounter that uses soft links and gives different paths to mounted file systems? There should be a path printed in between the words "but SNCSEQ at" and "has"; if that path really is empty it could be reading a file from the root path /configure/RELEASE so have a look there too. Finally, I'm not sure what will happen if the SNCSEQ installation itself has a definition for SNCSEQ in its own configure/RELEASE file, so make sure there isn't one set there. Let us know what you find... - Andrew -- English arose from Normans trying to pick up Saxon girls.
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
