1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Failure probing for event generator
To: Korhonen Timo <[email protected]>
Cc: Dayle Kotturi <[email protected]>, EPICS tech-talk <[email protected]>, EPICS core-talk <[email protected]>
Date: Fri, 23 Sep 2005 08:42:00 -0400
On Fri, 2005-09-23 at 13:50 +0200, Korhonen Timo wrote:
> Hi Dayle,
> although the problem was solved with Ge, I summarize it here as other
> people may have interest in this topic also.
> The card was not recognized because it needs a special configuration
> sequence.
> The EVG/EVR series 200 cards have been implemented according to the
> CR/CSR specification in VME64/VME64x standard (chapter 10 in the VME64x
> ANSI standard.) That is, before the cards are visible in the normally
> used access windows (A32,A24,A16,...) they have to be configured. This
> configuration happens in a separate address space which is
> geographically addressed (those who know PCI are familiar with the concept.)
> There are no jumpers or address switches to be set but on the other hand
> if the configuration is not done the cards are not visible in the normal
> windows.
> This would give many nice possibilities but unfortunately the concept is
> poorly or not at all supported in vxWorks at least (one can of course
> customize the BSP to have a window to the configuration address space.)
> For the EVG/EVR 200-series we implemented a 'hack' where in the
> eg/erConfigure the Tundra registers are saved, modified to give access
> to the config address space, the card is configured and finally the
> Tundra registers are restored to the original values. This is not the
> best method but at least it works. Except for the problem that Ge had:
> the mvme5100 BSP has a bug (or poor implementation) of sysBusToLocalAdrs
> routine and the dev support needed another hack to circumvent this bug.
> Would the CR/CSR concept be worth a short talk and a discussion in the
> EPICS meeting?
I think it would be an awesome topic.
> best regards,
> Timo
> Dayle Kotturi wrote:
> > Hi Ge,
> > Three things I'd suggest (based on my experience with 100 series hardware):
> > 1) make sure your EVG is properly "seated" in the crate. Even if LEDs are
> > on, I've found that board can be incorrectly seated. This happened with
> > 64x VME crates.
> > 2) ensure the top rotary dial is set to '2' and the lower rotary dial is
> > set to '0'
> > 3) change your card number from '4' to '0' if you only have one EVG
> > Step (3) may not be necessary to get it working.
> > You need to get a '0' return code from EgConfigure before you can get
> > any further.
> > The same suggestions apply to EVR (rotaries at '1' and '8', change
> > card to '0'). For EVR only, check that jumpers are set to '5' as
> > is documented on the board itself.
> > Dayle Kotturi
> > LINAC Coherent Light Source
> > Stanford Linear Accelerator Center
> > On Tue, 20 Sep 2005, Lei Ge wrote:
> >>Hello,
> >>I'm testing the event generator EVG200, but my IOC failed to probing the
> >>event-generator board. Could somebody give me some suggestions? Thank you
> >>very much.
> >>EgConfigure(4,0x2000)
> >>value = -1 = 0xffffffff = prsrv_cast_client + 0xff0f7b3f
> >>ErConfigure(6,0x1800,164,5)
> >>cd "/home21/home/leige/epicsApp/dbd"
> >>value = 0 = 0x0
> >>dbLoadDatabase("baseApp.dbd")
> >>devApsEg: Failure probing for event generator... Card disabled
> >>devApsEr: Failure probing for event receiver... Card disabled
> >>value = 0 = 0x0
> >>dbLoadDatabase("evgevr.dbd")
> >>value = 0 = 0x0
> >>Best wishes,
> >>Ge
Failure probing for event generator Lei Ge
Re: Failure probing for event generator Dayle Kotturi
Re: Failure probing for event generator Korhonen Timo
Prev: Re: Failure probing for event generator Korhonen Timo
Next: Re: striptool strangeness Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Error using Agilent E5810A LAN/GPIB Gateway Mark Wagner
