I am having an intermittent problem with channel access on a cygwin IOC. Sometimes when the IOC starts everything works fine, but sometimes I get the following behavior:
- No channel access clients are able to connect to any PVs on the IOC. I get the following types of errors:
corvette> caget dxpXMAP:med:mca1.ERTM
CAC: Unable to connect because "Connection refused"
CA.Client.Exception...............................................
Warning: "Virtual circuit disconnect"
Context: "164.54.160.5:5064"
Source File: ../cac.cpp line 1145
Current Time: Thu Sep 29 2005 13:49:55.763202000
Channel connect timed out: 'dxpXMAP:med:mca1.ERTM' not found.
- casr on the IOC produces the following, which seems OK to me.
epics> casr 50
Channel Access Server V4.11
No clients connected.
UDP Server:
UDP 164.54.160.111:50650(): User="", V4.11, 0 Channels, Priority=0
Task Id=0x103987b0, Socket FD=8
Secs since last send 34.40, Secs since last receive 0.12
Unprocessed request bytes=16, Undelivered response bytes=0
State=up
168 bytes allocated
Send Lock
epicsMutexId 0x10399060 source ../caservertask.c line 673
ownerTid 0x0 count 0 owned 0
Put Notify Lock
epicsMutexId 0x10399158 source ../caservertask.c line 674
Address Queue Lock
epicsMutexId 0x10399250 source ../caservertask.c line 675
Event Queue Lock
epicsMutexId 0x10399348 source ../caservertask.c line 676
Block Semaphore
There are currently 1176 bytes on the server's free list
7 client(s), 0 channel(s), 0 event(s) (monitors) 0 putNotify(s)
0 small buffers (16384 bytes ea), and 0 jumbo buffers (16408 bytes ea)
The server's resource id conversion table:
Bucket entries in use = 0 bytes in use = 16404
Bucket entries/hash id - mean = 0.000000 std dev = 0.000000 max = 0
The server's array size limit is 16408 bytes max
Channel Access Address List
164.54.160.255:5065
Any ideas on what the problem could be, or how to track it down? This is a new problem, I have been running cygwin IOCs for many months with no problem. I am developing a new application that has started to produce these symptoms.
- RE: Channel access problem on cygwin IOC Jeff Hill
Re: VxWorks TIMEZONE hack, anyone? Andrew Johnson
<2005>
2025
2026
RE: VxWorks TIMEZONE hack, anyone? Rees, NP (Nick)
<2005>
2025
2026
