> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> > Another possibly is that an IOC was connected before and was
> > restarted.
> What exactly do you mean by this? The cygwin IOC has indeeed been
> started and stopped many times.
Sorry, I sent out that message yesterday evening a bit too quickly. I meant
that an active IOC is bound to the CA server port. If that IOC is restarted,
on UNIX systems that port is by default placed in TIME_WAIT state where it
can't be reused until a timeout expires (even if the socket is closed
gracefully). However, the CA server code turns off that behavior by setting
socket option SO_REUSEADDR. In the windows port this step is not required
(the TIME_WAIT unavailability behavior does not exist) and SO_REUSEADDR was
observed, at least on certain versions, to be harmful so we noop out the
relevant OSI call. On POSIX setsockopt SO_REUSEADDR *is* enabled. If that
was not filtered out by cygwin then you might experience the diseased
situation I once observed where two IOCs were actually allowed by the IP
kernel to be bound to the same TCP/IP port. I don't well remember the
specifics other than observing some bizarre behaviors when this occurred.
> However, I have exited all channel
> access clients that are connected to that IOC, both on the local Windows
> machine and on other machines. Does this matter?
Shouldn't.
> Here is some more information which may be of interest:
> - When I was having the problem an SNL program running in that cygwin
> IOC was able to connect to the PVs fine. That is just a CA client,
> right?
When the CA client library communicates with local in-memory PVs it talks to
them directly using db_access, and bypasses socket communication altogether.
> - Other CA clients on the Windows machine were not able to connect.
They need socket communication.
> - Ohter CA clients on remote machines were not able to connect.
They need socket and IP communication.
> - Rebooting the Windows machine fixed the problem, at least for now.
> - The problem kind of seems like running out of a resource, perhaps with
> SO_RESUSEADDR as you suggested?
And if that does not take care of it then you must reinstall windows ;-)
Seriously, this might fix many things. Among them, this might have cleared
out a diseased situations where two IOCs were actually using the same TCP
port (because SO_REUSEADDR was allowed to be set by cygwin).
> One minor point is that cygwin is nice because I can set up soft links
> under cygwin so that the same configure/RELEASE files in every
> application work for Linux, vxWorks and cygwin. That does not work for
> win32-x86 since one needs to use Windows syntax for paths, not Unix
> syntax. cygwin also lets me install an ssh server on the Windows
> machine so I can do EPICS development on the Windows machine remotely
> with good performance, no need to be sitting in front of it.
I install and run the cygwin tools on my PC also. Personally, I just check
out the relevant EPICS base files from a remote CVS repository onto my PC. I
don't try to share the files between UNIX and windows because the line
terminators invariably get clobbered if I do (CVS adjusts them for me
transparently). I'm not too worried about disk space. I seem to always have
many different versions of EPICS checked out from different branches.
Jeff
- RE: Channel access problem on cygwin IOC Mark Rivers
Possible improvements to simulation mode [patch] Denison, PN (Peter)
<2005>
2025
2026
<2005>
2025
2026
