1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: readline on cygwin-x86
To: <[email protected]>, <[email protected]>
Date: Wed, 12 Oct 2005 17:59:15 -0500
Janet,
I am trying to use the readline library on cygwin-x86 with EPICS 3.14.7.
It looks to me like there are 2 problems in the configure/os directory.
1) CONFIG.Common.cygwin-x86 contains the line:
LDLIBS_READLINE = -lcygreadline5 -lcygcurses7
But recent versions of readline on cygwin don't have a library called cygreadline5, or cygcurses7, they just have a libraries called readline and curses.
$ ls -l /usr/lib/*readline* /usr/lib/*curses*
lrwxrwxrwx  1 epics mkgroup-l-d     12 Oct 12 17:40 /usr/lib/libcurses.a -> libncurses.a
lrwxrwxrwx  1 epics mkgroup-l-d     16 Oct 12 17:40 /usr/lib/libcurses.dll.a -> libncurses.dll.a
-rwxr-x---+ 1 epics mkgroup-l-d 540990 Sep 28 21:16 /usr/lib/libncurses++.a
-rwxr-x---+ 1 epics mkgroup-l-d 171170 Sep 28 21:16 /usr/lib/libncurses++.dll.a
-rwxr-x---+ 1 epics mkgroup-l-d    887 Sep 28 21:16 /usr/lib/libncurses++.la
-rwxr-x---+ 1 epics mkgroup-l-d 396098 Sep 28 21:14 /usr/lib/libncurses.a
-rwxr-x---+ 1 epics mkgroup-l-d 280186 Sep 28 21:14 /usr/lib/libncurses.dll.a
-rwxr-x---+ 1 epics mkgroup-l-d    793 Sep 28 21:16 /usr/lib/libncurses.la
-rwxr-x---+ 1 epics mkgroup-l-d 264080 Jul 28 22:58 /usr/lib/libreadline.a
-rwxr-x---+ 1 epics mkgroup-l-d 345644 Jul 28 22:58 /usr/lib/libreadline.dll.a
2) There is no definition of COMMANDLINE_LIBRARY, commented or uncommented, in any of the CONFIG files for cygwin-x86.
I fixed both of these problems by creating a new file CONFIG.Common.cygwin-x86 that contains the lines:
COMMANDLINE_LIBRARY = READLINE
LDLIBS_READLINE = -lreadline -lcurses
Once I do that, applications I build have command line editing.
Is this the correct thing to do?
Prev: Accessing ControlLogix PLC program tags with EtherIP Mike Forster
Next: Soft motor won't compile with GNU g++ 3.4 and beyond Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Accessing ControlLogix PLC program tags with EtherIP Kay-Uwe Kasemir
