1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Accessing ControlLogix PLC program tags with EtherIP
To: tech talk <[email protected]>
Date: Thu, 13 Oct 2005 10:00:08 -0400
On Oct 12, 2005, at 13:21 , Mike Forster wrote:
I couldn't find this path information previously on tech-talk and it
may prove useful to others using the EtherIP driver.
To access a program tag on the controller use:
Program:[Program name].[tag name]
such as:
Program:Magnet_control.magnet1_value
Hi Mike:
The thing is that the driver/device support
was based on documentation from AllenBradley.
Their document "Logix5000 Data Access",
1756-RM005A-EN-E,
a copy of which is available on
on http://ics-web1.sns.ornl.gov/~kasemir/etherip
states explicitly (page 4):
"Logix5000 tags have these properties:
 * name ... up to 40 characters"
Gee wiz, they copied the EPICS 40 char string
limitation!!
"* scope:
– controller (i.e., global), which you can access directly
– program (i.e., local), which you can not access via an
external device"
So by definition, access to program tags is
impossible.
We should thus add this to the list of
quirks we love about Allen Bradley ;-)
-Kay
Accessing ControlLogix PLC program tags with EtherIP Mike Forster
Prev: Soft motor won't compile with GNU g++ 3.4 and beyond Denison, PN (Peter)
Next: Re: Soft motor won't compile with GNU g++ 3.4 and beyond Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Accessing ControlLogix PLC program tags with EtherIP Mike Forster
Next: readline on cygwin-x86 Mark Rivers
