1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: autosave V4.1 and caRepeater
To: Aladwan Ahed <[email protected]>
Cc: "'[email protected]'" <[email protected]>, [email protected]
Date: Fri, 21 Oct 2005 14:35:32 -0500
I have not been able to figure out why this problem apparently
goes away when autosave's status PV's are loaded.  Autosave calls
ca_context_create() regardless of whether or not status PV's exist,
and it makes CA connections to lots of PV's in any case.
It must be the save_restore thread that's issuing the fork()
call, since this thread does all of save_restore's CA work.
Here's the slightly simplified calling sequence:
   st.cmd calls create_monitor_set()
   create_monitor_set() calls epicsThreadCreate("save_restore")
   save_restore() calls ca_context_create()
Is there some way I can prevent the save_restore thread from having
that file open, or if not would it be better to spawn it as a task
instead of a thread?
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
Aladwan Ahed wrote:
Hi Tim and Jeff,
I have noticed a strange behavior that I want to share with you when using autosave v4.1 for EPICS 3.14.7.
I use the utility to restore parameters for a Firwire EPICS server running at Linux fedora core 1, kernel 2.4
Problem:
When the autosave status pv's are not loaded (or not defined through save_restoreSet_status_prefix()) it will complain with the msg:
Can't connect to status PV(s) for list 'auto_settings.save'
If the EPICS server is terminated, it don't kill it self properly and keeps hanging around using -in my case - /dev/video1394/.
epics> exit
[root@pc5697 iocCCD]# whouses /dev/video1394/0
32261 ../../bin/linux-x86/ieee1394 ./st.cmd
When caRepeter is in the path and not already started, it will start and attach it self to the epics server process and ultimately to the /dev/video1394, then you see:
epics> exit
809 caRepeater
When I start the Firewire server again, it fails as the /dev/video1394 is till used by another process, and I need to force kill the previous epics process before I can restart the Firewire server again.
Solution:
1- The problem disappeared by loading the status pv's and define the autosave prefix. I managed to reproduce the problem every time so far.
2- If you don't care about the status PVs, be sure that caRepatear is already started before you start the autosave service.
Further Test:
I suspected that my application might have a thread that don't terminate properly, so I only built the server using autosave, I stopped caRepetar and I took away it from the path, I started the server, and then terminated it (exit), still when I list the processes I see:
[root@pc5697 iocCCD]# ps auxw |grep st.cmd
root 10736 0.0 0.2 9996 2432 pts/0 S 08:14 0:00 ../../bin/linux-x86/ieee1394 ./st.cmd
root 10745 0.0 0.0 4488 584 pts/0 S 08:15 0:00 grep st.cmd
Is that an expected behavior?
Re: autosave V4.1 and caRepeater Andrew Johnson
Prev: Re: UDP to CA_UDP hangs network? Steven Hartman
Next: Re: autosave V4.1 and caRepeater Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: autosave V4.1 and caRepeater Jeff Hill
