Mark,
As I recall, JCA 2.0.x had a package to support backward
compatibility with JCA 1.x. However, JCA 2.1.x introduced yet
another new API which isn't even compatible with JCA 2.0.x. JCA
2.1.x introduced several significant improvements (including bug
fixes) over previous versions.
The last time I checked, jprobe did not compile under JCA 2.1.x and
so I assume it is not being kept current. So, I would suggest trying
JCA 2.0.x or sticking with JCA 1.x if you want to use jprobe.
-tom
_________
Tom Pelaia, Ph.D., R&D Staff
Spallation Neutron Source, Accelerator Systems Division
Oak Ridge National Laboratory
On Oct 28, 2005, at 3:40 PM, Mark Wagner wrote:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
http://www.aps.anl.gov/xfd/SoftDist/swBCDA/jca/index.html says
"Your programs using the old API should still work with JCA2."
That doesn't seem to be the case. The package name has been changed
from
jca to gov.aps.jca. Changing the name to gov.aps.jca in the jprobe
source does not fix the problem, because it still references the 1.x
api, e.g., BadCountException, which does not exist in 2.x.
Is there some way to enable compatibility mode or should I use jca 1.x
with jprobe?
Mark Wagner [email protected] 206-598-0302
Unix System Administrator, Radiation Oncology
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
iD8DBQFDYn6VvOs2g/c480IRAg8XAJ9U8cDdnuwq5ITw6jES8Vuuq82EVACgjJZ6
6iXd4XS5hvXMgR/GJycO64c=
=LTOb
-----END PGP SIGNATURE-----
- jprobe does not work with jca 2.x Mark Wagner
Re: jprobe does not work with jca 2.x Kenneth Evans, Jr.
<2005>
2025
2026
<2005>
2025
2026
