1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: jprobe does not work with jca 2.x
To: "'Tech-Talk'" <[email protected]>
Date: Sat, 29 Oct 2005 11:09:13 -0500
I got the newer jar files jca-2.1.6.jar and caj-1.0.4.jar from
http://caj.cosylab.com/index.html.
With these it appears to read the environment without need of
command-line or other properties.  This is apparently a feature added
to JCA 2.1.6.  It makes things much easier.
It also fixed an overflow problem I was having in another CAJ
application.  Jprobe seems to work OK with the newer jars.  So
it would seem wise to get the latest version.
	-Ken
Re: jprobe does not work with jca 2.x Thomas Pelaia II
RE: jprobe does not work with jca 2.x Kenneth Evans, Jr.
Prev: RE: jprobe does not work with jca 2.x Kenneth Evans, Jr.
Next: Acromag IP231 16-bit Hight Density DAC EPICS driver? Luchini, Kristi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: jprobe does not work with jca 2.x Thomas Pelaia II
