1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: jprobe does not work with jca 2.x
To: Tech-Talk <[email protected]>
Date: Thu, 03 Nov 2005 11:39:08 -0500
Has anyone had a problem compiling the new JCA 2.1.6 source? We tried on both Linux and Mac OS X and get the same compile error because JNI.cpp is missing the stdlib.h include line. This header is needed for the calls to setenv() and such. Including this header allows JCA to compile correctly on both platforms. We didn't test other platforms.
-tom
On Oct 29, 2005, at 12:09 PM, Kenneth Evans, Jr. wrote:
I got the newer jar files jca-2.1.6.jar and caj-1.0.4.jar from
http://caj.cosylab.com/index.html.
With these it appears to read the environment without need of
command-line or other properties.  This is apparently a feature added
to JCA 2.1.6.  It makes things much easier.
It also fixed an overflow problem I was having in another CAJ
application.  Jprobe seems to work OK with the newer jars.  So
it would seem wise to get the latest version.
-Ken
RE: jprobe does not work with jca 2.x Kenneth Evans, Jr.
Prev: Re: Waveform soft record Steven Hartman
Next: Alarm in Epics Liyu, Andrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: jprobe does not work with jca 2.x Kenneth Evans, Jr.
Next: Acromag IP231 16-bit Hight Density DAC EPICS driver? Luchini, Kristi
