1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Waveform soft record
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Thu, 3 Nov 2005 09:53:12 -0500 (EST)
On Wed, 2 Nov 2005, Emmanuel Mayssat wrote:
> Now, I would like to create 32 independent waveform records such as
> iocname:ADC:adcID:pinNumber that will be a copy of one of the 32
> waveform records.
I'm not sure if I understand what you are trying to accomplish, but I
expect you can do what you are trying to do using a combination of
waveform records and compresss record(s), probably using "Circular Buffer"
ALG. See the Record Reference Manual for a description of the compress
record. If that won't do what you need, you can develop something which
will using the genSub record.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
RE: Asyn build under win32 Mark Bennett
Waveform soft record Emmanuel Mayssat
Prev: RE: caSnoop build problem Kenneth Evans, Jr.
Next: Re: jprobe does not work with jca 2.x Thomas Pelaia II
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Waveform soft record Emmanuel Mayssat
Next: RE: Asyn build under win32 Mark Rivers
