1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Alarm in Epics
To: [email protected]
Cc: "Williams Jr, Ernest L." <[email protected]>
Date: Thu, 03 Nov 2005 12:29:44 -0500
Hi, All
I wouldn't refuse to see Your comments :)
1. I looked on alarm code in ai record. After real actions and before
monitor process() calls
            checkAlarms(pai);
checkAlarms() function belongs to ai. But other records types have their
checkAlarms() functions.
Then checkAlarms() function calls recGblSetSevr( precord, ...) function.
It is macros. So we can EASY change macros and new function will write
message to errlog server (I don't know another suitable central engine
in Epics).
	After that we will have all alarms in one place. I believe that
advantages are clear.
1a. Just for information. D0 in Fermilab has done something similar.
They attached "hook to alarm". I don't see this way. I explain way to
substitute code. It could be way with "memory substitution". But this is
real hack and I am not sure it will work on any platforms.
2. I also have another misunderstanding.
	As I understood ALARM situation is when parameters go out of
range but equipment works perfectly. If equipment doesn't work correctly
it is ERROR situation.
	In simple (within device) ALARM situation operator tries to tune
parameters that go out from ALARM situation. If operator couldn't do
that he stops beam because it will become ERROR situation in machine
level.
	In simple (within device) ERROR situation operator stops beam if
it is technology or disable diagnostic detector.
	So ALARM and ERROR are basically different.
	Now Epics alarm severity has 4 definitions: NO_ALARM,
MINOR_ALARM, MAJOR_ALARM and INVALID. There are some sentences in Alarm
specification of Records book. It seems INVALID doesn't belong to ALARM.
It belongs to ERROR.
	Can anyone share another base idea about alarm/error in control
system?
Thanks, Andrei.
Re: Alarm in Epics Kay-Uwe Kasemir
Prev: Re: jprobe does not work with jca 2.x Thomas Pelaia II
Next: Re: Alarm in Epics Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: caSnoop build problem Kenneth Evans, Jr.
