On Nov 8, 2005, at 11:12 AM, Walters, M (Malcolm) wrote: I have been trying to run a Linux softIoc in the background by using the screen command. When I try to specify the startup script at the same time (i.e. "screen ./st.cmd"), the ioc starts but on any caget/caput/... command the screen terminates without any error message.
What happens if you specify the executable explicitly rather than starting the executable from the script?
i.e. screen /full/path/to/bin/linux-x86/iocExecutable st.cmd
If I start the screen and then run the startup script I don't have any problems. This problem occurs for every database we have tried. Has anybody else had any similar problems or any ideas what might be causing this?
We are running R3.14.7.
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
- Re: Running softIoc's in the background Paul Sichta
- Running softIoc's in the background Walters, M (Malcolm)
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
