1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Running softIoc's in the background
To: <[email protected]>
Date: Tue, 8 Nov 2005 13:09:42 -0500
Malcom,
I use an indirect method to call st.cmd. I can't recall why I ended up doing it that way. As Eric suggested I have specified the path for the executable. Does the envPaths file look correct?
$ cat st.boot_iocs1
#!/bin/csh
cd /eprun/ioc157/iocBoot/ioclin7
screen -d -m -S ioc -h 1000 ./iocstart
$ cat iocstart
#!/bin/csh
../../bin/linux-x86/lin7 st.cmd
-ps
----- Original Message ----- From: "Eric Norum" <[email protected]>
To: "Walters, M (Malcolm)" <[email protected]>
Cc: <[email protected]>
Sent: Tuesday, November 08, 2005 12:23 PM
On Nov 8, 2005, at 11:12 AM, Walters, M (Malcolm) wrote:
I have been trying to run a Linux softIoc in the background by
using the
screen command. When I try to specify the startup script at the same
time (i.e. "screen ./st.cmd"), the ioc starts but on any caget/
caput/...
command the screen terminates without any error message.
What happens if you specify the executable explicitly rather than starting the executable from the script?
i.e.
screen /full/path/to/bin/linux-x86/iocExecutable st.cmd
If I start the screen and then run the startup script I don't have any
problems. This problem occurs for every database we have tried. Has
anybody else had any similar problems or any ideas what might be
causing
this?
We are running R3.14.7.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: Running softIoc's in the background Steven Hartman
Running softIoc's in the background Walters, M (Malcolm)
Re: Running softIoc's in the background Eric Norum
Prev: Re: Running softIoc's in the background Eric Norum
Next: Re: Running softIoc's in the background Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
