1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Running softIoc's in the background
To: <[email protected]>
Date: Wed, 9 Nov 2005 16:49:42 -0000
I see the same behaviour when I try it in this way. Using screen with a
script that calls the ioc startup script works, as suggested by several
people.
$ cat ./st.screen
#!/bin/sh
./st.boot
$ screen ./st.screen
Thank you for all of the help.
Malcolm
Sent: 08 November 2005 17:23
To: Walters, M (Malcolm)
Cc: [email protected]
Subject: Re: Running softIoc's in the background
On Nov 8, 2005, at 11:12 AM, Walters, M (Malcolm) wrote:
	I have been trying to run a Linux softIoc in the background by
using the
	screen command. When I try to specify the startup script at the
same
	time (i.e. "screen ./st.cmd"), the ioc starts but on any
caget/caput/...
	command the screen terminates without any error message.
What happens if you specify the executable explicitly rather than
starting the executable from the script?
i.e.
screen /full/path/to/bin/linux-x86/iocExecutable st.cmd
	If I start the screen and then run the startup script I don't
have any
	problems. This problem occurs for every database we have tried.
Has
	anybody else had any similar problems or any ideas what might be
causing
	this?
	We are running R3.14.7.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: Running softIoc's in the background Kay-Uwe Kasemir
Prev: Re: Running softIoc's in the background john sinclair
Next: Re: Running softIoc's in the background Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
