I am trying to build EPICS (3.14.7) for RTEMS-uC5282 on host linux-x86. However relatively early in the build process, after entering src/libCom/O.RTEMS-uC5282, I get an error. The last part of make output is: Installing shared library ../../../lib/linux-x86/libCom.so.3.14 ln -s libCom.so.3.14 ../../../lib/linux-x86/libCom.so Installing html ../../../html//freeList/freeList.html mkdir ../../../html mkdir ../../../html/freeList Installing html ../../../html//gpHash/gpHash.html mkdir ../../../html/gpHash make[3]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.linux-x86' make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../.. T_A=RTEMS-uC5282 install make[3]: Entering directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.RTEMS-uC5282' make[3]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.RTEMS-uC5282' make[3]: Entering directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.RTEMS-uC5282' make[3]: *** No rule to make target `../O.Common/osiFileName.h', needed by `inc'. Stop. make[3]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.RTEMS-uC5282' make[2]: *** [install.RTEMS-uC5282] Error 2 make[2]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom' make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src' make: *** [src.install] Error 2 Any help would be appreciated. Thanks. John Dobbins Lab for Elementary Particle Physics Cornell University Ithaca, NY
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
