1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RTEMS-uC5282 build problem
To: "John Dobbins" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Wed, 16 Nov 2005 10:44:28 -0800
Hi John,
> make[3]: *** No rule to make target `../O.Common/osiFileName.h', needed
> by `inc'.  Stop.
I wonder if OS_CLASS is not being set to RTEMS for your build.  Either your base/configure/os/CONFIG.Common.RTEMS isn't setting it (OS_CLASS=RTEMS has been removed?) or your CONFIG.Common.RTEMS-uC5282 file is not including CONFIG.Common.RTEMS or something of this nature.
Stephanie Allison
Re: RTEMS-uC5282 build problem John Dobbins
Next RTEMS-uC5282 build problem John Dobbins
Prev: RTEMS-uC5282 build problem John Dobbins
Next: Real time video with epics Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: RTEMS-uC5282 build problem John Dobbins
