1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Next RTEMS-uC5282 build problem
To: Till Straumann <[email protected]>
Cc: John Dobbins <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 17 Nov 2005 09:18:45 -0600
On Nov 16, 2005, at 3:34 PM, Till Straumann wrote:
Delete or #ifdef the line
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
in src/RTEMS/base/rtems_config.c
Note that the current check for a particular CPU ( #ifdef __mc68040__ )
is *really* bad. Supporting the RTC is a BSP feature, i.e.,
the code should check for a particular BSP rather than CPU.
Agreed, but I don't think that there's a standard way that BSPs identify themselves.
Suggestions?
Also, it would be better to only use the RTC on
'known with support' boards rather than not using it on
'known w/o support' boards...
FWIW, the current CVS snapshot does have the ifdef that lets this build for the uC5282.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RE: RTEMS-uC5282 build problem Allison, Stephanie
Next RTEMS-uC5282 build problem John Dobbins
Re: Next RTEMS-uC5282 build problem Till Straumann
Prev: RE: Real time video with epics Singleton, SJ (Steve)
Next: record/device support general style question Jens Rekow
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Next RTEMS-uC5282 build problem John Dobbins
Next: RE: Real time video with epics Aladwan Ahed
