1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: record/device support general style question
To: "Jens Rekow" <[email protected]>, <[email protected]>
Date: Fri, 18 Nov 2005 10:09:44 -0000
There is no need to have the device support distributing the values.
It is simpler to do this via database processing
and have the other records extract the values for
themselves from the original input record.
Pete
> -----Original Message-----
> From: Jens Rekow [mailto:[email protected]]
> Sent: 17 November 2005 15:38
> To: [email protected]
> Subject: record/device support general style question
> My way so far is another: There is one AsynDriver-powered record
> (stringin) which retrieves and holds the status string. That
> value is read
> by a longin record via dbGetField() in a standard device
> support, which
> extracts the information and distributes to all the other
> relevant records
> via dbPutField(). Thus these other records don't need any
> device/record
> support implementation themselves but are set remotely.
> Unfortunately this
> complicates handling the alarm/invalid states of these records.
> So the question is:
> Would it be better to have already my AsynDriver-powered record, which
> reads the status bytes, distributing the values to the
> different records
> via dbPutField()?
> Alternatively I like the idea of only one device support
> implementation
> for several records which is flexible using the INP field as a
> parameter...
> Any suggestions?
> What could be more 'stylish'?
> Thanks in advance,
> Jens
Re: record/device support general style question Rok Sabjan
Prev: Getting CA data with VC Xu HuiJuan
Next: RE: Getting CA data with VC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: record/device support general style question Liyu, Andrei
Next: Re: record/device support general style question Rok Sabjan
