There is also an additional advantage in what Peter is suggesting.
If you distribute the values in the database it is easier and more
transparent how you distribute alarms, which can be very important when
maintaining your database.
Rok
Owens, PH (Peter) wrote:
There is no need to have the device support distributing the values.
It is simpler to do this via database processing
and have the other records extract the values for
themselves from the original input record.
Pete
-----Original Message-----
Sent: 17 November 2005 15:38
To: [email protected]
Subject: record/device support general style question
My way so far is another: There is one AsynDriver-powered record
(stringin) which retrieves and holds the status string. That
value is read
by a longin record via dbGetField() in a standard device
support, which
extracts the information and distributes to all the other
relevant records
via dbPutField(). Thus these other records don't need any
device/record
support implementation themselves but are set remotely.
Unfortunately this
complicates handling the alarm/invalid states of these records.
So the question is:
Would it be better to have already my AsynDriver-powered record, which
reads the status bytes, distributing the values to the
different records
via dbPutField()?
Alternatively I like the idea of only one device support
implementation
for several records which is flexible using the INP field as a
parameter...
Any suggestions?
What could be more 'stylish'?
Thanks in advance,
Jens
_____________________ _ _ _ _ ____________________
|_| |_| |_| |_| |_|
Rok Sabjan Cosylab
Head of EPICS Section http://www.cosylab.com
Email: [email protected] Teslova ulica 30
Phone: +386 (1) 4776-767 SI-1000 Ljubljana
Cell: +386 (41) 796-666 Slovenia
__ _ _ _ _ __________________ _ _ _ _ __
|_| |_| |_| |_| |_| |_| |_| |_| |_| |_|
- RE: record/device support general style question Owens, PH (Peter)
infrastructure questions rolf
RE: Writing to PVs Liyu, Andrei
<2005>
2025
2026
Getting CA data with VC Xu HuiJuan
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
