1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Getting CA data with VC
To: "'Xu HuiJuan'" <[email protected]>, <[email protected]>
Date: Tue, 22 Nov 2005 17:03:14 -0700
Hello Xu HuiJuan,
I found your zip file on the tech-talk archive and successfully downloaded
it to my machine. I was able to get it to build after making some small
changes - specified path to EPICS include directories, bypass missing
resource files, proper path to dll's at runtime etc.
When I debug this application I see that the channel name is an empty string
at this line.
AcPVName=(LPTSTR)(LPCTSTR)m_Channel;
Later on it creates a channel, but is unsuccessful because the channel name
is empty. The code does not take a different path if the status isn't
ECA_NORMAL.
status=ca_create_channel(PVName,0,0,0,&CHID);
Further below it crashes when it calls ca_clear_channel() for a channel that
has not been created (CHID wasn't initialized).
status=ca_clear_channel(CHID);
The application appears to run w/o crashing if I force a valid channel name.
Hoping that this advice proves to be useful,
Jeff
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Friday, November 18, 2005 10:25 AM
> To: 'Xu HuiJuan'; '[email protected]'
> Hello Xu HuiJuan,
> Your attachment, demo1.zip, was removed upstream of my host by e-mail
> filters at our site. Zip files can no longer be used to communicate source
> code over e-mail with users at our site. Perhaps you can attach the source
> files and the make files individually.
> > I use the Visual C++ .net to get ca data.
> > This is my program.
> > It can be compiled but can't be executed.
> > I don't know how to solve it.
> It's difficult to make any guess as to the cause with only this very
> minimal information. Please send an error message or better yet a stack
> trace from your visual C++ debugger if there has been a crash.
> Did you have a look at the MS VC++ build options in the CA reference
> manual?
> Does the caget program, installed by the EPICS base build, work at your
> site?
> Jeff
> > From: Xu HuiJuan [mailto:[email protected]]
> > Sent: Friday, November 18, 2005 12:12 AM
> > To: [email protected]
> > Subject: Getting CA data with VC
> > Hello,
> > This is my program.
> > Thanks!
Prev: EDM on Windows + Hummingbird? Michael E Urashka
Next: Re: EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Getting CA data with VC Lawrence T. Hoff
Next: Problem booting EPICS on RTEMS-uC5282 John Dobbins
