-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On Thu, Oct 27, 2005 at 11:16:45AM -1000, Maren Purves wrote:
> looks like you have a Makefile.Vx in your soruce directory.
> If so, either delete it or rename it to something else.
There was no Makefile.Vx in my source directory.
I followed the maze of Makefile includes to the culprit. In
${MY_EPICS_BASE}/configure/CONFIG_COMMON
there is
BUILD_ARCHS = $(EPICS_HOST_ARCH) $(CROSS1) $(CROSS2)
Changing that to
fixed the problem. (I then changed it back after compiling edm.)
I'm an EPICS newbie so I'm looking for a bit of enlightenment with these
questions:
Why would edm, or any other extension, use BUILD_ARCHS, when they will
run on the EPICS_HOST_ARCH only?
How can I tell edm, without touching stuff in ${MY_EPICS_BASE}, that it
shouldn't build for the target(s), only the host? I tried mucking with
stuff in ${EPICS_EXTENSIONS}/configure and ${EPICS_EXTENSIONS}/src/edm
to no avail.
Is there an extension that is a shining example of the proper use of
the EPICS 3.14 build system?
> Mark Wagner wrote:
> >I'm trying to build EDM on a linux-x86 host, which seems to go OK.
> >However, it seems as though it is trying to be built for the vxWorks-68040
> >target too, which causes all sorts of problems. How can I make it not
> >do that?
> >epics 3.14.7
> >edm 1-10-1zf
> >extensionsConfigure_20040406
> >extensionsConfig_20040406
Mark Wagner [email protected] 206-598-0302
Unix System Administrator, Radiation Oncology
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFDg8y0vOs2g/c480IRAlJDAJ9fcylurjZuLp9ofGeDsGO4BL/wtQCdE5CX
ueo46SB9CVWzWItMF2fjsU0=
=g2ZX
-----END PGP SIGNATURE-----
- Re: EDM wants to build on vxWorks-68040 target. Why? Ernest L. Williams Jr.
- EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
RE: Getting CA data with VC Jeff Hill
RE: EDM wants to build on vxWorks-68040 target. Why? Singleton, SJ (Steve)
<2005>
2025
2026
<2005>
2025
2026
