Hello Mark et al,
This problem seems to have come about as a result of a change to the EDM
build round about version 1.10.1ze; prior to that it used 3.13 style
make files and built only on the client platform.
If you have a shared EPICS base that is used by a number of developers
to build things for vxWorks IOCs as well as client applications,
changing BUILD_ARCHS in base/configure/CONFIG_COMMON is not a practical
solution, as the change affects everyone. I came up with a solution
that doesn't affect programs other than EDM (though it involves rather
more effort). In the MAKEFILEs in all of the subdirectories of
extensions/src/edm, replace any
PROD=
definitions with equivalent
PROD_HOST=
Definitions, and any
LIBRARY=
LIBRARY_HOST=
Definitions. Then edm is built for host architectures only.
Regards
Steve Singleton
-----Original Message-----
[mailto:[email protected]] On Behalf Of Mark Wagner
Sent: 23 November 2005 01:58
To: [email protected]
Subject: Re: EDM wants to build on vxWorks-68040 target. Why?
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On Thu, Oct 27, 2005 at 11:16:45AM -1000, Maren Purves wrote:
> looks like you have a Makefile.Vx in your soruce directory.
> If so, either delete it or rename it to something else.
There was no Makefile.Vx in my source directory.
I followed the maze of Makefile includes to the culprit. In
${MY_EPICS_BASE}/configure/CONFIG_COMMON
there is
BUILD_ARCHS = $(EPICS_HOST_ARCH) $(CROSS1) $(CROSS2)
Changing that to
fixed the problem. (I then changed it back after compiling edm.)
I'm an EPICS newbie so I'm looking for a bit of enlightenment with these
questions:
Why would edm, or any other extension, use BUILD_ARCHS, when they will
run on the EPICS_HOST_ARCH only?
How can I tell edm, without touching stuff in ${MY_EPICS_BASE}, that it
shouldn't build for the target(s), only the host? I tried mucking with
stuff in ${EPICS_EXTENSIONS}/configure and ${EPICS_EXTENSIONS}/src/edm
to no avail.
Is there an extension that is a shining example of the proper use of
the EPICS 3.14 build system?
> Mark Wagner wrote:
> >I'm trying to build EDM on a linux-x86 host, which seems to go OK.
> >However, it seems as though it is trying to be built for the
vxWorks-68040
> >target too, which causes all sorts of problems. How can I make it not
> >do that?
> >epics 3.14.7
> >edm 1-10-1zf
> >extensionsConfigure_20040406
> >extensionsConfig_20040406
Mark Wagner [email protected] 206-598-0302
Unix System Administrator, Radiation Oncology
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFDg8y0vOs2g/c480IRAlJDAJ9fcylurjZuLp9ofGeDsGO4BL/wtQCdE5CX
ueo46SB9CVWzWItMF2fjsU0=
=g2ZX
-----END PGP SIGNATURE-----
Re: EDM wants to build on vxWorks-68040 target. Why? Mark Wagner
RE: EPICS base compiling using Visual C++ 2005 Express guobao shen
<2005>
2025
2026
Re: EDM wants to build on vxWorks-68040 target. Why? Ernest L. Williams Jr.
jprobe does not work with jca 2.x Mark Wagner
<2005>
2025
2026
