Dear Dr. Jeff and Dr. Vladimir,
Thank you very much.
I succeeded in the compilation after removing the TD from the fdopen
specification.
If I tried to build static libraries, there was no problem. But if I tried
to build shared
libraried, I must copy the manifest specification file for each exe or dll
file into
bin/win32-x86 manually.
I also found that I can not execute the catools such as
caget/cainfo/camonitor correctly.
The only error message is "caget.exe has encountered a problem and needs to
close."
Can you give any suggestion?
Thanks again.
Best Regards,
Guobao Shen
J-PARC Control Group
> I looked into this "w+bTD" verses "W+B".
> The purpose of this code is to open an identical type of
> temporary file on all OS. This particular problem is, of
> course, in Microsoft specific code working with previous
> versions, but not with Visual C++ 2005.
> The very latest documentation at MS with a 2005 time stamp on
> it lists "T"
> and "D" as valid Microsoft specific options to _fdopen. This
> therefore smells like a bug at MS. Nevertheless, the proposed
> change appears to work - not creating any permanent files on
> the disk. This is probably because roughly equivalent options
> are specified to the preceding open().
> We have committed the suggested change - ETA R3.14.8.
> Jeff
> > -----Original Message-----
> > From: Vladimir Sirotenko [mailto:[email protected]]
> > Sent: Tuesday, November 22, 2005 9:34 AM
> > To: guobao shen; [email protected]
> > Subject: Re: EPICS base compiling using Visual C++ 2005 Express
> > Try to do the following, it worked for us:
> > Antelope failed to run correctly because it could not create a
> > temporary file.
> > Modify src\libCom\osi\WIN32\epicsTempFile.cpp and remove
> the TD from
> > the fdopen specification.
> > pNewFile = _fdopen ( fd, "w+b" ); instead of pNewFile =
> > _fdopen ( fd, "w+bTD" );
> > Vladimir
- RE: EPICS base compiling using Visual C++ 2005 Express Jeff Hill
RE: EDM wants to build on vxWorks-68040 target. Why? Singleton, SJ (Steve)
Re: EDM wants to build on vxWorks-68040 target. Why? Ernest L. Williams Jr.
<2005>
2025
2026
<2005>
2025
2026
