As long as your IOC and the machine where you run your client
application are on the same network, you do not have to set any of
these environment variables.
Normally you will need to set the variables only if one of the
following is true:
- your IOC is on a different network than your client
- you want to "hide" local IOCs from your client (e.g. you are
using a CA Gateway and your client should only see the Gateway, no
other local IOCs)
- you have changed the port numbers that Channel Access uses (by
setting variables on the IOC)
If you are starting a regular IOC on any machine on the local network,
your client will successfully connect without any environment variable
being set. This is what CA was designed for: to find all IOC data in
the local network, no matter which IOC on which machine actually runs
the record that your client wants to access.
Hope this helps...
Ralph
Xu HuiJuan wrote:
I know what happened.
I added three environmental variables:
EPICS_CA_ADDR_LIST the address I want to link
EPICS_CA_AUTO_ADDR_LIST NO
EPICS_CA_SERVER_PORT 8888
After I deleted these variables, the CA_Get can link my own soft IOC.
But I want to link the IOC data on another PC. What is the right
environmental variables?
Thanks!
- environmental variables Xu HuiJuan
RE: Using subArray Abbott, MG (Michael)
Re: Using subArray Noboru Yamamoto
<2005>
2025
2026
RE: environmental variables Jeff Hill
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
