Noboru Yamamoto wrote:
> Michael Abbott wrote:
> > I am writing device support for a subArray record so that I can read
> > small slices from a very large array provided by a device.
> We had similar problem when we tarted to construct KEKB
> control system. So we developed a new record called Compact
> Subarray record. It just copys amount it needs from a source
> record. We need to add new API in dbaccess library, which is
> not present in the standard EPICS base, to support this record.
> If you have an interest on this record, I will be happy to
> send source code.
Thank you for the thought. I'll see if I can make things work with subArray first. If I have problems I'll be in touch!
I'd prefer to use the standard record type (even if I am milding abusing it) if I can. You say also that your Compact Subarray "copies amount it needs from a source record" -- do you mean that the source has to be another Epics record, or can it be purely device data?
- Re: Using subArray Noboru Yamamoto
Re: environmental variables Ralph Lange
<2005>
2025
2026
Re: Using subArray Carl Lionberger
<2005>
2025
2026
