1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using subArray
To: Michael Abbott <[email protected]>
Cc: [email protected]
Date: Wed, 30 Nov 2005 10:31:17 -0800
Hi Michael,
These sorts of decisions seem like a matter of timing to me. If you wait until the subarray is modified (if it ever is) your project will be late, so you can't do that. If you modify it yourself but not in the manner that ends up in base you will always have to be fixing each new release at your installation regardless of whether or not the subarray gets changed or at least until you resynchronize with a newer more compatible version. While it needs to be repeatedly fixed you have to document it in case you leave the project. (not to indicate one shouldn't document everything anyway!) If you write device support for records you can use without modification it might take longer now but the job will be done.
Carl
Michael Abbott wrote:
On Wed, 30 Nov 2005, Carl Lionberger wrote:
I think the thing to do would be to separate out the soft support for the subarray record from the rest of the record; it really is too closely coupled now. Then whatever buffering it uses to deal with the outside could be in the device support code which would be tailored as needed.
Should I take this as a hint that my hack is likely to come unstuck? In truth I'm tending back to using separate length and index controls managing standard waveform records, but it isn't that code's turn yet...
I took care to avoid tampering with epics itself, so the only change I've made is that my subArray init_record reassigns MALM to a much larger value. I haven't worked that code very hard yet, as other stuff has intervened, but at first glance it seemed to work ok.
Carl Lionberger
Control System Software Engineer
Berkeley National Laboratory (LBNL)
(510)486 7503
Using subArray Michael Abbott
Re: Using subArray Carl Lionberger
Re: Using subArray Noboru Yamamoto
Re: Using subArray Michael Abbott
Prev: Re: Using subArray Michael Abbott
Next: EPICS R3.14.8 Release Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Using subArray Abbott, MG (Michael)
