1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using subArray
To: Noboru Yamamoto <[email protected]>
Cc: Michael Abbott <[email protected]>, [email protected]
Date: Wed, 30 Nov 2005 09:13:42 -0800
I think the thing to do would be to separate out the soft support for the subarray record from the rest of the record; it really is too closely coupled now. Then whatever buffering it uses to deal with the outside could be in the device support code which would be tailored as needed.
Carl
Noboru Yamamoto wrote:
Carl Lionberger wrote:
The thought was that the subarray record would be purely a soft record, and any hardware device support would be for waveform records that the subarray would read from. The MALM code makes sense in this context because the API for the dbaccess (as Noburu alluded to) always starts at element 0 of the source record. Therefore it is impossible to index an element larger than the buffer space you have.
In the case of a module which have more memory than the main memory on CPU board, you might want access part of memory using a subarray record.
But the subarray record does not allow it.
We wanted to divide a very long waveform into several small waveforms so
that we can monitor it on medm/dm2k. In this case, we need O(N * N) size
of buffer memory for EPICS database, where N is a size of source waveform. Using the compact subarray record, it can be reduced to O(N) buffer size.
As Carl pointed out, the specification of the SubArray records is a result of the dbaccess API. In other words, if the dbaccess library
have had an API which allow access to a part of waveform data, we
would have another specification of the SubArray record.
( And it could be quite similar to our compactSubArray record.)
-- Carl Lionberger Control System Software Engineer Berkeley National Laboratory (LBNL) (510)486 7503
Re: Using subArray Michael Abbott
Re: Using subArray Carl Lionberger
Re: Using subArray Noboru Yamamoto
Prev: Re: Using subArray Noboru Yamamoto
Next: Re: Using subArray Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
